So a few weeks ago Markus asked if anyone could cut a sprocket and some tec. heads which led to talk on the thread about kustom kart kid cutting some heads using a spud screwed into the spark plug hole, which sounded like a good idea. When I received the heads I lightly sanded the heads on a surface plate to see if they were some what flat and then I made a spud to turn them. At this point my first thoughts when I heard this trick were confirmed. When I checked the surface around the head with the indicator, it was out .015 . You would think the plug hole would be square to the surface, but not in this case. With no way to adjust it I decided to build a adjustable fixture to fly cut them on the mill. Interesting to see that the later
model heads are smaller chambered as when you take .010 off you get into the squish area. and on a older head you don't.
