shouldn't do it! 70's Manco Chopper
#21
I have one that I am currently rebuilding my self right now mine I believe is all original accept the rear wheel wich I am trying to find right now just curious what are you doing about the seat mine is missing also
Keep up the great work
Will probably just make a pan out of wood and cover it myself something more custom looking.
#22
Well got a little farther, spaced the front wheel correctly and came up with a way to lock the front drum into place. The weld isn't the prettiest but i know its strong! For the back rim i moved it back about a 1/4" and made some brackets, the brackets are just tacked in for now i still have to center the wheel, the sprocket hits the bracket so i will have to figure out what to do there and also lock the drum in. I stuck the motor in that i think I'm going to use, may have to use a 1/2 gal tank this gal one touches the frame and i want more room to adjust the motor. Well enough rambling for now :hammer:
#24
I see nothing wrong with the bracket or welds you did to the front. In fact, I think it's cool when you leave traces of custom work behind.. "the signature". I like this bike so much that, if I can redirect some build funds, I may re-create one myself for the next years build-off (but with a few tweaks to the design). Really cool bike and nice job bringing 'er back to life. :thumbsup:
The techumseh looks good in there.
#25
Thanks Fire! I'm thinking this mini is going to take off slow with the small rear sprocket???? This bike will be for my kid in a couple years so not to worried I guess, your thoughts on how it will work:confused:
#26
If I counted right, looks like a 40 tooth rear so without a jackshaft that is a tall gear like 4:1 to 3.5:1 depending on your clutch teeth 10/12. If those tires are as tall as they look, that will also affect the gearing. My thoughts, it will take off slow due to the sluggishness of having a tall gear but have a better top end but that depends on engine size too. You can find gear calculators somewhere in this forum. I think an old Rupp I bought a short while ago came with a 40 tooth sprocket and I changed it to a 60 which gave me a better lower end response while losing some top end. What do you want it to do?
#27
Well it will be for my son who will be around 9 or 10 when he rides it so i guess slow is good.
#28
That's coming along nicely , just curious the two bits of round bar welded under the engine plate, do you think that was standard issue or put on afterwards?
Love the choppers
#29
When I put the Honda wheels on this one the rear sprocket was small too so I bought a 64 tooth sprocket and welded it to the rim.Along with the torque converter the gear is real nice.I like the look of this build your doing,and I agree with Fire the Tecumseh looks real good in there.:thumbsup:
#30
Love the choppers
ya i see what your talking about, to me it looks original but who knows for sure with this one. Also mine and the original one pictured have a full length foot peg bar, but Markus just has the short pegs
#31
I have a baja worrior geared up like that very slow take of with my 188 pounds of self on it but when it gets up to speed does like 50 have a 6.5 clone from HF and no t/converter with a small kid on it be careful
#32
Thanks, i was thinking of buying a sprocket and making it work like on your Chopper.
#36
No new work yet, I'm restoring a yamaha moto bike of all things. Also going to install a 6- pack intake on my 340 demon soon. May start up in a few weeks I know the direction I want to go with this chopper at least.
you guys need to get going on these, it sounds like the one I had is maybe coming back into my possession. My buddy that bought it from me wants me to do some paint/build work on a Bonanza for him with the Delta 1 being a forum of payment.
So get building and give me some inspiration!!!!
other than finding a period correct original white paint HS40 with metal tank he has not touched it and it still looks like this:
