Howdy All,
I have an Azuza Mini Bike with a 6 HP OHV Tecumseh with a TAV2. I want to build a side car for my two girls to mess around with. The mini bike has 8" Azuza Tri Star rims with 480/4-8 studded tires on them. This mini bike is way over powered. It is hard to keep the front tire on the ground. It will pull a wheelie even at a speed of 15 MPH! I have added a cable stop to limit throttle movement to about 1/4 travel and it will still go 15mph with me on it! I weigh 180 lbs too! I bought the bike ,as is, knowing I was going to build a side car and figured the extra power would be good. It may be too powerful?:doah:
Here are my plans for the build
Questions for you all:
I have a Harbor Freight Pipe Bender. Lots of sch80 seamless pipe (1/2",3/4", 1", 1-1/4", 1-1/2", 2") and some angle and flat steel. I am working on getting a pipe notcher next. I have access to a mig welder and awesome welders thanks to my work. I want to become a better welder myself. Practice practice.
Can a mini bike with a side car still do wheelies?
Thanks in advance for all suggestions! If you want to me to give updates I will.
:wink:Hec
- Add front forks and steering head from a Yamaha PW50. Bearings and all.
- Bending my own handle bars.
- Adding a center kick stand.
- Add mono shock seat suspension like chipper and jdogg (thanks for the inspiration!)
- I will be using a Farmall H farm tractor gas tank for the side car body. The metal is pretty thick on this bad boy:thumbsup:. Farm tractor fuel tanks are plentiful here in Nebraska. You can get a good deal on one that is a little flaky inside. My tank is solid and weighs about 40 lbs as is. I will be carpeting the inside or applying bed liner to the inside. I got the idea from this link: MINIBIKES WITH SIDE CAR
- Possibly upgrading the brakes. It currently has a 4-1/2" Azuza Drum brake.
- Possibly putting small spring to add suspension to the side car wheel assembly.
- Mount a fuel tank in front of the seat to replace the stock Tecumseh tank. The stock tank forces you to ride with your right leg opened up. Awkward for me even harder for kids.
- Where should the side car tire be positioned in relation to the front and rear tires? Should it be closer to the rear? Centered between the front and rear?
- Should I use the same size 8" wheel for the side car or something smaller?
- What can I do to improve braking?
:wink:Hec
