I have been trying to get some of the small details worked out on my build , there sure is a lot left to do lol
I did some more on the rear brakes mounted the caliper and master cyl , made the actuater rod bellcrank and a foot brake lever pivot mount
the foot pedal is not made to length yet as it depends on foot peg location , the red tube is how it sits on the frame
Had to make some clevice ends , used 1/2 " square stock and turned and drilled on my lathe.
Had some bar stock aluminum scraps salaveged from an industrial table legs so I turned them down on the lathe and drilled/ tapped them for footpegs ,made a couple of weld on plates for mounts.
I have given some thought to my gas tank and may bend up some stainless and see if I can weld it up or I may use a stock tank mounted on top of the frame with a stainless cover over it so it looks custom , not sure yet .
More to come.
Rob
