Ive seen 1 or 2 people build snowbikes around the internet, but I could never find a proper build thread. I'm going to start a thread here to document what I'm doing to modify this bike to make a snowbike. I have never messed with any mini bikes of any kind. I'v been riding gopeds since I was about 12 or 13 and I'm a die hard 2 stroke guy, so this is a huge learning experience for me. Also, I am learning how to weld on this project.
I started off with this weird blue frame with an angled motor mount, looks like it was set up for a jack shaft. Cut that angled part off and welded a flat 1/8inch piece of steel for a proper motor mount. I found a 5hp briggs engine in my crawl space from who knows when. Threw some gas in it, and it started right up. I picked up a 16mm china carb, and made an intake for it. I will be running the chinese torque converter from ebay as well. Tracks came from a craftsman showblower. These are different than most that I've seen since the track is driven by the wheel attached to the shaft and theres no chain.
https://imageshack.com/i/pnRnFYafj]
https://imageshack.com/i/pnJwOGVLj]
[/URL]
https://imageshack.com/i/pnYcsMGHj]
[/URL]
https://imageshack.com/i/pmuoRMX5j]
[/URL]
https://imageshack.com/i/plzca5lij]
[/URL]
https://imageshack.com/i/plV9L4B5j]
[/URL]
https://imageshack.com/i/pm9n5ymWj]
[/URL]
https://imageshack.com/i/plNGHPBSj]
[/URL][/URL]
I got some tubing that is exactly 1 inch ID and welded that to the forks and the ski will attach to that. The tracks are held together by 2 pieces of steel that I cut using the snowblower parts as a template for length. The wheels and bearings for the track are riding on a 3/4inch shaft and I will be welding coupler nuts to the shaft that will engage the wheel because the centers are hex cut.
The project is ongoing and not even close to finished. I will post more updates as they come along. I'm open to hearing constructive criticism or just ideas on how to make my life easier with this project.
