I traded a old briggs 8hp Vert shaft rider engine for a monster Wisconsin robin engine. Its a ey29 or something like that. I want to use it because its so weird looking.. ut:
I don't have a pic of mine yet but its smilier to the one below but in red and looks brand new and a tad bigger.
It was on a Yazoo Mower from the 80's The guy used the crap out of it and the mower fell apart around the engine. Its 14" tall to the top of the engine fins. I didn't measure to the top of the tank since I will not be using it unless I can put it on the top of the frame in front of the seat. I haven't figured out what mini I want to put it on. Im thinking maybe my New Bird Lark?? It should fit further in the front of the frame.
Anyway....... It runs pretty good no smoke or knocks but it really doesn't want to run without the choke being closed somewhat.. It rev's fine but when you let off of it it wont idle it wants to die.. At max rpm it runs perfect.
At idle with the choke closed a bit to keep it running it Surges a little.
I haven't done anything except put gas in it and check the oil and change the plug. It has a real nice thumpy exhaust note...Like a tt500 Yamaha if you have ever heard one of them at idle.
What should I check next?
Not Mine!!!! But this one's ugl....um... cool too!
