So I am starting the teardown on the Scrambler and I need to know if the front tube is tweaked. It clearly has had some work down up at the neck which I will clean up and make much better but when I flipped it over it seemed like the tube underneath if off center,
The welds that re on it look factory (far different then the welds at the neck repair) so I don't know if this was the design or if the person who welded the upper tube also rotated the down tube. Like I said, the welds under the motor plate look absolutely factory and there is nothing under the plate that would suggest the tube was in any other position.
