1971 Speedway Scarab,
The Good : 1971 date code hs40 / with slanted intake. has compression. original exhaust . Both original clutches. Good clutch cover/ not cracked, front disc brake with caliper. Rear brake hub. Wheels with speedway tires. Surface rust will clean up. Sebac shocks . Good frame and swing arm. Gas tank is very nice , clean inside no dents.
The Bad : forks are messed up , wrong bars, spray bomb paint
The bike is in Phoenix Az . I will be there weekend of Jan 21. I would like $500 obo . If no takers , I will part it out
Thanks K.C.
Thanks K.C.
