I need some info . OK i wanna use the asuzalite 5" rims. Im wondering what regular sprocket that will adapt to these type rims not a drum. Basically im going to shim from the rim to a sprocket with some type of adaptor so i can use a caliper. Any help will be great. Thanks
some of the stellars came with a disc brake set up ! your frame does not have a stock bracket for one which is good because after market calipers don't fit it anyhow . and the limtco calipers are almost non existent :laugh: but you can use an after market caliper and make your own bracket but i don't know if i would try to space a sprocket off those plastic wheels that is not a drum style to distribute weight :thumbsup:
