HS40 brand new re-pop carb on ebay model #631918 $10.49 fs which is a cheap,quick option to get you going. Probably not as good as the oem Tecumseh original carb but they seem to work ok as I've used several off them. If I'm going to use the old original carb I usually soak it good then glass bead it prior to rebuild.
