stovetop19's - Mini Stunter 125 - (Anything Goes)
#22
#24
Build Day 4
Build day 4 is done. Turns out my original wheel base length measurment was wrong:scared: So I now have to splice in another 5 inches into the already "finished" back bone tubes. So here is what I accomplished today....
1. Cut and weld the back bone tubes to the steering stem.
2. Cut my frame in half to lengthen it
3. Splice in additional 5 inches of tubing
4. Grind welds smooth
Check out my photos or the video below:thumbsup:
https://www.youtube.com/watch?v=wPyo8HpxPw0&feature=youtu.be
#30
Your build is just great , love the fab work going on here . On your bender where did you get the return spring from ? I have the same cyclinder on mine and need a return spring .
#35
Build Day 7
Got day 7 done!
Today I got the handle bars located and mounted. I also got the Engine mostly installed.
To install the handle bars, I was given some old mini bike triple tree top clamps that had removable handle bar clamps, they came from Ratbike228, a member here on OldMiniBikes. I just had to locate and drill holes in my top triple clamp.
The motor required alot of shimming and aligning, but once I had it where I wanted it, I used some flat stock and made brackets to secure it to the frame. I am also using some of the donor bikes frame to help speed up the fab time on the mounts.
See my photos or the video below.
https://www.youtube.com/watch?v=Hhp7tM63Oxo&list=PLMBpnHRM4osjVUwA23SnAFhlSZth_XI6r&index=8
