I have taken a picture of the underside of my minibike. The sprockets on the jackshaft are both 15 teeth. The distance between the tipss of the teeth and the shaft of the swing-arm is only about 1/4". Is this normal? Or should the sprocket on the engine driveshaft side have fewer teeth so that its diameter would be smaller and hence give the chain a little more room to travel thin this small gap? See pic.
Thanks,
Eric the novice
Thanks,
Eric the novice
