t555trailblazer's - Bonanza powered by Chrysler……… Power bee 700 - (Vintage Class)
#84
Polishing wheels is a mother hubbard, but in the end it pays off. Can you feel your finger tips still? :laugh:
They look great!
#86
Dremel makes several small polishing and sanding pads. They don't last very long, but can get into the tight spaces. You'll spend a small fortune on them as they last maybe 10 minutes before evaporating.
#90
Thanks for the advice Dr. shop teacher. If they only last for 10 minutes, I would have to buy a entire pallet load…lol
I did make a visit to Harbor freight and picked up a couple things
#92
More Harbor freight stuff. It was about $16 out the door with the coupon. The kit contains a nice variety of wheels. The compound is good too.
#93
Too cold to paint anything outside, so I just keep polishing. Have the sprocket and brake assembly going. Need to find a tiny screw that keeps the wire in the brake light switch.
#94
Got back from vacation and been busy at work. I haven't had much time. Did get a chance to get it sandblasted. Turned out nice, this frame is sweet!!!Wish I could've kept the original paint but it was too far gone. I try to find a couple minutes in the evening to work on polishing the rims. It's a great way for me to relax after work.
#98
Install the new electrical parts, cleaned everything up and did the settings. I got SPARK !!!!
At least enough that when I spin the flywheel by hand I got zapped. Had to test it. Going to route the plug wire out the side and put the Killswitch near top of engine.
#99
Got a chance to go out in the garage for a short time tonight. No big deal but I did get a chance to make a kill switch wire. Little details that need to be taken care of. Going to look for a self grounding toggle switch so that I only need to run one wire. I'm sure they make one. Going to a local electronic store to see if they have it.
