Taping threads for a crank end bolt
I'm going to install an end bolt in a 3hp Briggs to retain the clutch...The existing hole is not tapped... I'm seeing online that 5/16 x 24 is standard for clones...Any suggestions for the smaller 3hp crank....What size drill bit for the correct tap size.. Building a standard Taco 22...... 60's vintage...
chrisr
The tap will let you know the correct bit to use as a pilot hole. User owend may have a crank drilling guide that you may be able to purchase. I bought one from him a few months back.
