Tav vs clutch on my application.
I'm about to build two minibikes for my 9yo sons for Christmas. I'm going to use azusa frame kits and stock non-hemi predators that I have sitting in the boxes still. I'll probably grab them a header, carb, and filter to start off. I have built one predator with billet parts, ported head, black mamba cam and some extras and will eventually do some more serious mods to theirs. They want the minibikes to run at the dragstrip (local 1/8 mile) and I was wanting to know if I should grab them a cheap torque converter or a clutch for these bikes since later they'll be making decent power and turning a good bit of rpm's. My boys weigh 80lbs and I'm wanting them to launch decent and still run good on top end. E.T. means more the mph to me. I know the torque converter will launch good but how will topend be later if the motors are turning 6000-8000rpm's? Any help will be much appreciated. I have a drag car and would like to have them something to run while they are at the track, just want to start them off close to stock but have a some room to grow as they get used to racing them.
Similar question here my friend!
I just bolted on a GTC TAV to my modified Predator and am trying to figure out if I should go back to a strong clutch or make this thing work....
I went ahead and ordered a mongrel clutch and going to try it. Nobody could tell me if a stock tav could hold up to 8000 RPMs.
What brand and series are you running, and have you modified the tav any?
The tav2 is a comet brand and yes I have modified it slightly without altering the original parts. A garter spring swap will delay engagement, and one more trick did help alot. I wont talk about the other mod but I can show you thru email. Lighter weights that are now available can delay engagement even more. I also swapped the rear spring but not sure if that helped or not.
