TAV2-30 on a Clone
any way i try to fit the tav2-30 on a clone doesn't work.
is this the wrong torque converter for a clone???
it only shows a tecumseh in the installation instruction.
:hammer::eek:ut:
CarPlayLB
The TAV will work fine on a clone engine. You just need to clock it to clear the cylinder head. You may also have to grind one or two fins from the back of the support plate
everything seems to fit now. the finger grip on the rear oil plug has to be
shaved down but the torque converter is tight up against the crankcase
and there is no interference with any other metal.
time to put it on the MX frame.
:thumbsup:
