Can you replace the
Tried all different settings. Starting at 1 1/4 to 1 1/2 on the low speed and 1/12 on the high speed. Haven't even tried to adjust hi speed yet.
FINAL ADJUSTMENTS (NON EMISSION ENGINES)
Start the engine and allow it to warm up to normal operating temperature (3 - 5 minutes). Set the speed control to the
HIGH or FAST position. From the recommended preset position, turn the main mixture adjustment screw in (clockwise)
slowly until the engine begins to run erratic (lean). Note the position of the screw. Now, turn the screw out (counterclockwise)
until the engine begins to run erratic (rich). Turn the screw in (clockwise) midway between these two positions. This will
be the best setting. (diag. 21, 22 & 23).
Set the speed control to the IDLE or SLOW position. Adjust the idle mixture screw following the same procedure used to
adjust the main mixture adjustment screw.
