hopefully its just the brass shaft that worn and not the carb body as well. You can get the new replacment shafts easy enough. these should actually be addressed and changed along with a rebuild on older carbs as usually they are worn and actually cause a lot of idling and tuning issues. newer replacements are usually steel, so keep it clean so it does not wear out the carb body, the felt washer/seal can sometimes be added too but have to sometimes modify the spot on the carb body that retains the throttle shaft return spring on the older carbs.....just depends on the era of the carb.
use your engine numbers to look up the carb breakdown list for the correct part number for the shaft.
