there's a lot of room here for different approaches. i like my approach as it's direct and pretty clean looking. On my picture i usually use a 90 degree elbow on the throttle cable to avoid an issue, i just had not implemented it yet. Positioning the carb where i do allows easy access to the choke lever (and it doesn't hit the torque converter cover), and i can get the float bowl off for maintenance or jet change easily. i don't really like Tecumseh's original intake manifolds as they have a lot of bends, and they basically move the carb under the exhaust and to the other side of the motor, and down. This makes simple maintenance harder, as there isn't enough room to work (without removing the carb from the engine.) I'm sure tecumseh positioned the carb this way for a good reason, but it doesn't work for me personally.
