i got real lucky when i was building this motor. i found a bearing cover real cheap on ebay.....:thumbsup:
bearing cover next to stock cover.
also note i clip off the governor parts.
when using a bearing cover it takes a different crank. there will be a grove cut in the shaft about .500 from the cam gear. this is for a snap ring that is installed before putting on the crank seal.
i also got lucky and found a new crank real cheap on ebay.
now that i have a grove crank for a bearing cover and know the distance. i can just cut a grove in my next future build and not buy a new crank.....:thumbsup:
