here is something i did over the summer. i took a complete stock ohh-engine and milled the head .040 on my lathe.
i also gave it the same treatment as my built motor got. use the aftermarket style retainers and keepers with a set of factory 15+ pound animal springs. thats what the guys at dyno cam rate them at. then installed a steel camshaft out of a newer flathead hs-50. something i notes about the newer flathead camshafts. they are lighter because they are machine out like the plastic camshafts with the valve relist built into them. i just remove that part before installing it. sorry no pictures of it. like i said before it looks just like the plastic camshaft,but steel. also i mic it and they have about .010 higher lift lobe then the older flathead cams do. timing on the engine was advance to 30+ degrees
something else i notes, the intake did not match the head,so i went ahead and port match that and clean up the intake side too.
now we are really talking about budget build here. took the stock rod and polish the rod beam up....:doah:
engine was built to run in a stock drag class. 10hp and under with stock cast iron flywheel and no aftermaket racing cams or carb's for example a mikuni carb. only a aftermarket air cleaner and you can rejet your stock carb. this class was really setup for the clone guys so they could put a new motion tube and jets. for me all i could do is install adjustable hs-40-50
carb.
kept the engine and bike kind of crusty looking so it would not stand out.......:laugh:
unfortunately the first race the throttle unit broke internally. causing it to fail. funny thing was the throttle caught enough cable to open the carb,but at this point the guy next to him(clone engine) got a head start by a bike or so. the bike ran him down and almost beat him......:doah: that guy end up running his bike all the way to the finals and he got beat by a kid that might of weigh 80 pounds on a clone engine. so i was still very impressed on how much power this ohh-motor has. if the cable just didn't break.......:doah: it has a thumb throttle on it now.....:thumbsupnly way to go...
carb.
