Tecumseh OHH55 Info Needed
Where can I find info on the Tecumseh OHH55? looking for stuff like parts compatibility across different models (e.g. cams, valve spring diameter, flywheel, crank and piston assembly, etc.), general specifications, and any kind of upgrades I have the possibility to be able to do. Thanks!
partstree.com has a cool feature. Find your model and type, or spec number, locate your part, and the site will tell you which engines used that part. It takes a few minutes, but I use it quite often. You do need the type or spec number off the shroud or tag.
That's a big help. The manuals I've found all are only including info for how to use the engine, nothing like individual parts and compatibility and all that.
Edit: I wish there was a way that it would tell me what technically "fits" instead of just what the part came in... like related parts, that sort of thing. Problem being that'd be VERY hard to accomplish, soo...
Interesting that much of the parts in the ohh lineup work in flatheads... I wonder if the cams do???
