Tecumseh Pull Start Housing Mounted Lighting Alternator for sale on Ebay
You are correct. I don't have the drive shaft. However I am including everything you need to build your own. All that is needed is an old socket that fits your crankshaft nut. A 3/8" drive socket will work perfectly as the Dremel flex shaft collar sits perfectly centered in the square 3/8" socket hole. The Dremel flex shaft collar has set screws on the side so you can replace the flex shaft if needed. I think this is a better way to go than the cheap stamped nut cover flex shaft. If you break the OEM flex shaft your screwed.
I'm going to add that diagram to the Ebay listing.
Thanks
Hec
