The Mutt
Hi guys. Not completely sure if this is a minibike, I posted pictures a while back of this contraption I built out of a Chinese scooter. It had a 33cc 2-stroke engine, and hadn't run for a while. I was messing around with the motor about a week ago, and got it to run for a bit, then stripped out the spark plug hole in the cylinder head. Since this motor doesn't have a seperate cylinder head, I decided to buy a 49cc motor with my birthday money. While I'm waiting for that to come in, I decided to fix up the frame a bit, it had bent because it was never designed to be ridden at an angle especially with my weight. P_20150205_152205.jpg
Looks like those footpegs are going to dig into the ground when you try to turn. I also suggest ape hangers:thumbsup:
I welded in a reinforcement tube today.
The footpegs have a way to go before they hit the ground, the photo just makes it look like they're a lot lower than they are. And ape hangers? Hmm, I'm intrigued. If I can find some from an old bicycle, then I'll put them on.
