Thoultle Conection
For any engine that is not orginaly built for a mini bike.. Like a engine for a powerwasher, or genator. How do you conect the thoulte cabe?
I'm use to conecting the ones for like techesa motors
please
Help
I hate to bring this old thread back but I need some ideas for linkage bracket
Ive worked on lawnmowers and other stuff but not mini bikes
maybe some pictures?
my mini bike has an old tecumseh engine that ran great but no spring return
throttle linkage setup or whatever it is. the guy that had it before used fishing line which is just plain:censure:
KB2ROCKET
judging from your posts you are frustrated I understand you have a good motor and a good minibike and no way to get the throttle to work relax breathe deep and lt me make this easy for you the first thing you should do is
1.find a return spring with a hook at both ends put one of the ends through one of the holes in the throttle stop plate then pull the spring in whatever direction is nesissary to return the throttle to idle then hook the other end of the spring around a bolt or through a hole if yo cant find anything to attach it to then you must make a bracket with a hole in it to attach your return spring once you have a goo throttle return and only then should you move on to the next step
2.I am going to assume you have a twist throttle and a cable on your bike
now you need to get a cable clamp and clamp the cable housing (the outside) to the engine alot of people clamp it to the blower housing but if this dosent give you the correct angle to pull the throttle open you can mount a bracket to the engine that will give you a better angle
once this is complete move on to step 3
3. at this point you need to find another hole on the throttle stop plate to put the inner part of the cable through if you cant find a good hole you may want to drill one . once you thread the cable through slide a cable stop on to the end of the cable and tighten it down. any adjustments that need to be made can be made with the cable stop and or the cable clamp
their is no simple answer for throttle hookups you just have to be a little crafty
if you need throttle parts everything you need is here
http://www.gokartsupply.com/thparts.htm
A good idea that my dad used for years on my gokart I had when I was little was this: Pretty much the same KB2ROCKET except on the throttle cable attachment part. I enlarged one of the holes on the throttle stop plate just large enough to fit a small bolt through.
I bought 3 nuts that fit that bolt and a couple of flat washers. I then got an electrical eyelit connector that fit the end of the cable perfectly. Alright F this im getting a picture, hold on.
#18
Alright here we go.
I guess I only used 2 nuts but I tightened them as hard as I could with a couple of small wrenches so the bolt was tight but the eyelet had room to move around in between those two washers. I have had this setup for 3months now with no problems and I wip around on this thing almost everyday it seams(stress relief lol)
Its nothing fancy but it gets the job done.
