Here is a nice new Tillotson set up for gas for a stock to modified clone motor.
This carb has received a little TLC by me as you can see in the photos. The carburetor is ready to go with the velocity stack attached. You will need a manifold which I will have later this week or you can get your own.
Pop-off set to 11 Lbs. fulcrum arm height to .075 correct for gasoline. High flow EC fuel strainer cap, machined shutter screw, polished and profiled throttle shaft, EC linkage plate.
$165.00 (as shown) Shipped to your door.
Before/After throttle shaft
Before after throttle screw and shutter
Before/After Venturi:
Before/After V-Stack
