Time to take out the Trail King....
After the ride on my Hawg-Ty it is time to get the Homlite Trail King on the trails again. A fun mini bike with one rough ride! It has one leaf spring in the frames middle section and old school wheelbarrow tires. It is built-like-a-tank, and with the two speed gearbox will climb most objects found on a mountain hiking trail. I has a CHI-Com engine now putting out 9 HP due to a slight modification.
A charging system for onboard batteries and charging a cell phone. A LED Head light was added and a flashing red tail light added to help prevent being rear-ended by motorcycle riders doing 80 MPH on some of the trails. It is a common problem here in NM.
The mini had just been restored to riding condition.
The TK does OK in "normal" trail mud.
As it stands today.
8 Amp charging coils, Voltage regulator, LED lights, Li-ion battery pack,cell phone charger, and a rear tire mud flap to stop
the mess when riding on muddy trails. I built a tuned exhaust pipe with a quiet muffler and spark arrester. The sound is a
nice low rumble, not at all what you'd expect.
I got motivated today and dug out the Trail King. After a bath, I changed the engine oil, cleaned out the carburetor (the little idle jet always like to clog on these CHI-COM engine clones) adjusted the chain tension, lubed the chain and all the chassis Zirk fittings and checked the tires and filled the front t o8 PSI and the rear t o10 PSI, just enough for a "smooth" ride but not slip the tire under load and tear the inner tube.
I took the TK for a two-mile ride and all is working normally on the back roads and maxed out on pavement.
I did a short video on the mini running, it is very windy here, sorry for the sound.
I took the Trail King out to Oak Flats here in NM. It had snowed last night and the ground was very muddy. The TK ran very well without even a hiccup. I had to keep the speed below 20 MPH due to the skinny tires and very loose,damp soil. I had several unplanned "deviations" of course as I rode down the trails.
I was approached by a few hikers who wanted to know about the TK which they were keen on.
I ended up driving 10 miles on the trails and the bike got a good coating of mud. It was fun. I did take a few videos today of the ride. For some reason, the vids are of a blue hue. I'm hoping it is a camera setting.
Here is one of 11 minutes or so. Sorry for the heavy breathing, I'm no longer 28 anymore,HA!.
I'm going to take out the Trail King today to a higher elevation and try to video again. It seems GoPro has a problem with the videos being blue. I'll set up a QRP HAM radio transmitter as well and see if I can reach both USA coast.
