Hi,
First of all thanks for all the additional replies. Second, I did end up getting spark after I sanded the points with medium grit sand paper and then cleaned the the points with white paper and a little aerosol contact cleaner. I also made sure the condenser was getting good ground by sanding the contact point on the armature body/housing that it screws down onto. Spark is nice when spun by hand, and I am optimistic about it.
I found a dial indicator on amazon. https://www.amazon.com/Indicator-Magnetic-Point-Precision-Inspection/dp/B002YPHT76/ref=pd_lpo_469_bs_t_2?_encoding=UTF8&psc=1&refRID=ECWN9R3NSQG6W7X0MMZX It comes with a base for a really good price. It seems pretty cheaply made/harbor freight quality or worse, but I don't plan to use it much and the reviews for it aren't that bad, so I might try it. The good news is Amazon has a really good return policy if this dial indicator set turns out to be total junk.
MB165, it is funny that you mention setting the gap using feeler gauges like that. I heard of a old timer using either a penny or a dime to set the gap as it is supposedly the same size as its spec. I'm sure he also set the points using a match book cover. :laugh: I'm 85% sure that this engine has never had the flywheel off just based off the looks of everything under there, the buildup of dirt and the (small amount) of grease on the points looks like it has never was cleaned. Based off of what the mechanic who sold it to me had told me. I can see no other bolt marks where the stator had been torqued down. I might try firing it up as is just to see what happens.
"There are no failed experiments, only more data."
