tubless tires fit tighter on the bead. if you pull the standard tire off a split wheel and change to a tubeless tire. the tire fits much tighter. if you dont need a tube, why wast the green. tube is needed on non sealed wheels or sealed wheels with the valve stem in them that just wont seal for some reason, like the bead is too rusty damaged bead or just a low quality wheel.
