I'm wondering if anyone sells spacers individually or in a set. I have a Predator 212 with 3/4" shaft with a TAV2 30 clone with 5/8" driven shaft.
The shaft with the sprocket would need spacers with a 3/8" keyway, and the front would need 3/4" washer(s).
I bought a different sprocket and it was a little wider than original and is throwing off my belt alignment. I'd need a narrower spacer on driven shaft or else a slightly thicker spacer on the motor shaft (preferable).
Looking around locally I don't see anything that would fit. Maybe OldMiniBikes sells them? Didn't see them on the site, maybe I didn't search the right terms.
