Tote Gote Frame Only
Hi All,
My second Gote to go is an unknown model year, although I believe it has a 760 front end with the original twist throttle... There is one jack shaft included and the two wheels as you see it. The original set of front forks comes with, however they have a funky-welded set of non-original bars on them. Easy to fix if you weld.
The frame is in good shape with poor quality additions to it as someone attempted to install a non-original motor. (see photo)
I believe the frame can be restored to original. My plan was to use only a cutting wheel and polishing disc. I also have other parts available if needed... 150/0ffer
