Trail Horse Custom / MX 500
Biffmini
I made up some inner wheel spacers, packed bearings & installed wheels.
I ran into a problem when installing & testing brake band.
I used J-B Weld to install new liner, cleaned band with acetone.
While testing the band the liner let loose :( I sure thought I was done with the band. Do over....
Any ideas on a better adhesive to use on the liner
Looks like the metal was not roughed up so the JB Weld had nothing to stick to.
I suspect if you hit the inside of the metal with some 80 grit and really give the JB Weld something to stick to it would hold fine.
Look how smooth the liner is where the JB Weld was, so you'll need to scratch that up to if you reuse the same liner...
Biffmini
So why use a band brake? Wouldn't a disk brake or even drum brake be a better choice.?
I thought long & hard on it and
I thought long & hard on it and decided to keep the original to the bike band brake. I just like the old school look.
They also work quite well especially with new parts.
With that being said, if I don't like the preformance, I'll be upgrading too disc.
I'm working on a front disc now...
Biffmini
I moved on to to front brake.
I'm determined to get a working hydraulic caliper using the original Speedway disc.
My first attempt was a no go caliper was to small & didn't open up enough to fit disc and vintage wheel wobble....
So I got a larger caliper & so far it's looking like its going to work out well. 20220104_183032~2.jpg
I drilled & taped another hole in the caliper bracket and was able to mount caliper where it needs to be. One bolt is not going to cut it so I'm working on a bracket to solve that.
So I got a larger caliper & so far it's looking like its going to work out well. View attachment 285729
View attachment 285730 View attachment 285732
Looking good sir. I was going to ask if you had experiencved any runout issues withthose Azusa wheels. I believe every set I sold back in the day was asked to be returned. I used to tell people to try clocking them to get the best possible runout and hope for the best.
Biffmini
So what model brake caliper are you trying? I have a speedway scorpion missing the brake caliper. If your setup works is it ok if I copy it?
ATV front brake caliper ebay
Although I think your application & mine are night & day different.
I'd ask in the vintage thread, about possible replacement for your Speedway or a Speedway group.
I've got days & hrs. Searching. This is my 2nd one & still not sure it will work.
Biffmini
I now have a working hydraulic front brake & cut out my mud guard out of black acrylic sheet. I'm now In the process of moving backwards, just when I thought I was done with the rear end. I've decided to add a chain tensioner to swing arm to make up for the run out in the rear wheel.
I've fabed up a weld on tensioner with the help of Havasu Dave for sharing his tensioner design.
It's now time to to dial in placement. Remove swing arm & grind, weld and repaint. A redo I'll be glad I tackled......
20220123_101952.jpg 20220123_101852.jpg 20220130_132534.jpg 20220125_101818.jpg 20220130_131907.jpg 20220130_131954.jpg 20220123_104107.jpg
