Trail King ride in Coyote Canyon....and it rained.
Rapidrob
I dusted off my Trail King from a couple of years of dust, and decided to take it for a ride in Coyote Canyon, 15 miles from my home. The weather looked "iffy", but was going to be in the 60s all day. I had gone through the mini to make sure where I was to be riding, the mini would not break down. Help is a long ways away.
The engine is not original to the bike, being replaced with a CHI-COM copy of a Honda 6.5 HP engine. All the original drive parts including the automatic clutch brake main drive made by Maximatic are original. This device is fantastic in how it works. As RPM increases it starts to dive the belt as any of today's torque converter do, but it has a feature others do not. The "clutch" always senses torque being applied and will adjust to the most efficient RPM to the oil filled drive gear box. When torques has stopped, it works against the engine, and breaks the engine to slow the bike down. A very strange feeling, but once you know how it works, the bikes brakes are hardly ever used! This really comes into play going down hill.
This bike was used in the 50s for Uranium Prospecting up at Yellowstone, Idaho.
I built a tuned exhaust and installed a spark arresting muffler that still allows power when needed but the engine noise in really reduced. A nice low rubble.
Installed is a High-Rise air intake manifold using a foam filter to allow crossing of shallow streams and mud puddles.
The two speed gear box is really handy, with low-speed being very strong on steep inclines or declines.
The platform behind the seat is designed to hold 500 pounds! The original rear tire was 6-plys and inflated to 50 PSI if needed.
The bike has a custom-made 2ND seat, this allows a rider to have a decent ride with foot pegs added for them.
I modified the exhaust so all the "pick-up bed" could be used.
I put a high current alternator on the engine and an AC to DC converter/ battery charger to run the LED headlight and charge a cell phone if needed.
A mud flap was installed to keep the dust/mud from being flung onto the rear deck, which it did at first.
A large, easy to reach Kill-Switch was installed. Off-road at 10-15 MPH, range is 25 miles. On dirt roads, at speed about 35 miles. Top speed is twenty-five, governed.
I drove to the canyon and decided to drive up the two-mile-long dirt road to check all things running were A.O.K. They were. I picked up the first trail head at the one-mile marker. This trail runs on the North rim of the canyon, and is an easy ride with only a few rock/boulder areas to transit.
I always carry: Water, tools, repair parts, first aid kit, tire repair and one extra gallon of gasoline.
End of Part 1 of 6
Rapidrob
Part 2 of 6
I climbed to the first trail head. The engine was running strong. There is a large rock formation that must be climbed in order to get to any of the "fun" trail heads.
Once through the restrictor gate to prevent 4-wheelers, I started down the North Rim of the canyon.
It is a fairly steep decline. Lots of rocks and boulders to drive over/around.
The little "doughnut tires" actually do better than you'd think. There is only one leaf spring on the whole bike. And it splits the frame in half. The ride is not as bad as you would think it would be.
You sit upright, balance is learned and felt. The little mini is very maneuverable at any speed.
There is a sheer drop-off to the right. No time for "Hold-my-beer" riding.
End of part 2.
Rapidrob
Part 3
The ride is fun. You have to "stay on your toes" as every 50 yards is something different to drive over or through.
Every now and then the trail opens up, and you can blow out the cobwebs.
This trail heads back to the main dirt road. It is a fun climb back up the canyon wall.
Much steeper than it looks, the Trail King blasted its way up the slope. The road is just over the ridge, and so is that storm cloud!
I drove up the road again and much further another mile or so to the 2ND trail head of the day. A much longer by several miles trail back to the trailer. Just behind me was the storm. I was hoping it would pass by.
The trails ride the slope of the North Wall of the canyon and heads East across the bottom of the canyon and up the opposite wall. The tries held their own and did not slip to the left.
It was about this time it got dark real fast. For the rest of the photos, I've increased the brightness so you can see more details of the trail. The storm was now 1/2 mile behind me.
The looses rocks really make this a fun ride. The engine brake is working well and traction is solid on most turns and hard leans.
The canyon walls are like a layered cake, several outcropping of limestone fault lines and ridges. It was a very steep decline here.
Sprinkles are just starting to fall on my neck.
I'm now at the floor of the canyon. It has just started to rain. I'm three miles from the trailer and will have to ride through some "interesting" areas to get back. That is a flood arroyo to my right.
A junction point. I would normally go to my left to add another few miles to the trail, but that way is all uphill, and it is raining lightly now.
The trail narrows as it skirts the tree line. I really enjoy the narrow lanes as it test your skill at keeping upright.
End of part 3.
Rapidrob
Part 4 of 6
The rain started to increase. I sped up a little. Dust on the trail was no more which is good, dust turning into mud is not, and we have a mud here in New Mexico called Caliche, they make adobe bricks out of it. It clings like epoxy when wet to anything or anyone.
The trail gets a little rough in places. Hang on if you can.
The trail has it good pars as well. I'm moving pretty fast here. The Rain In Spain Falls Mainly ...on the back of my shirt. It is starting to come down pretty good now. It is raining sideways from the wind, North to Southeast.
The throttle is wide open now. Trying to beat getting soaked to the bone. Lucky no one else is on the trail....they have smarts.
I just realized I have much farther to go than I thought. The rain has covered the autofocus. I stopped to clean the camera and the lens.
OH, Boy!! Back into the tree line. A respite from the rain for a little while. The trail is turning towards the parking lot, two miles away. Lots to cover between here and there.
End of part 4 of 6
Rapidrob
Part 5 of 6
Climbing a steep grade. Getting closer to the parked trailer. Temperature is dropping as well. The mini has not missed a beat.
The dreaded "Power Line route" I'm going to bypass as much as I can for safety. The rocks are getting wet. Not good for traction.
I'll go down into the arroyo. Not too smart but cuts off 1,000 yards of the trail.
The storm is now over the top of me. My front is now getting wet. At least there is symmetry in my life...
I had to jump over a felled tree. The Trail King held its own doing this. It is raining harder now. Lens needs to be cleaned again.
I'm now fully in the arroyo, there is no way out for a long way. I could climb the walls, the bike would not in case of a flash flood.
I'm able to get into the tree line again. Remember I have adjusted the photos to lighten them up. It has gotten pretty dark now. Still a mile to go to the trailer.
TK37.JPG Back into the arroyo, I remember lots of rocks to drive over/around.
The trail is soaked. So am I. The rocks are wet. I'm launching them all over the place. Still a 1/2 mile to the trailer. At least there is no lightning.
End of part 5 of 6.
Rapidrob
Part 6 the end.
I can join the Soggy Bottom Boys, no use trying to stay out of the rain, it ain't happening.
I see a way out up ahead. This is good, I'm getting out of the arroyo and I only have to climb the wall of the canyon a couple of hundred feet to get back to the trailer.
Out of the arroyo and onto the "normal" trail. The alarm is going off for the camera battery.
Another 1/4 mile to the trailer. The ride has been fun to so far, so good.
Still climbing up to the parking lot. No problems. Engine and mini are running like a Swiss watch.
Battery for the camera just died. 250 yards from the trailer. I made it back with no issues.
Here is the last photo as the battery died. I left the image alone, this is what it really looked like. I'm less than 100 yards to the road, then to the parking lots.
What fun ride. Other than a shower by nature, all went very well indeed. The Trail King showed how well it was designed. The engine brake, the two speed transmission and that funky suspension never let me down. I've been riding trail minis for 65 years now...I'm still having fun a 75!
I always enjoy when you post your trail rides- keep them coming. In addition, I'm very envious (as I am sure many others are) of all the beautiful areas you have to ride! Just curious, are these trails legal for riding your bike? I would think that there would be all kinds of misc. off road and motocross riders-yet you seem to always be all alone on the trails...
Michael
Rapidrob
Yes, within 15 miles of my home, there are over 1,000 miles of trails to legally ride.
About 100 miles South of me,is a park strickly made for off road vechicles. It is called Gordie,s Hill. You can ride down an arroyo for 25 miles one way! Ive done it once. What a hoot.
I did another ride today on my Hawg-Ty modified mini at Oak Flats for 12 miles,to check out a new centrifical clutch.
I took 600 photos and will edit them soon ans so a post.
Ill be doing another ride on my Hill Topper soon as well
