I would be careful going overkill, like NEO said, too much brake can be bad. I had a 150cc scooter that had too much brake, wish it had regular china drum brakes but had disc front and rear. look at the lever wrong and it locked up, that combined with too high seat height made for a nasty toss...
You want to have plenty of brake, but only be able to lock up the wheels at or near full pedal pressure. You want to take into consideration your ROTATING mass, because if you have light wheels and tires, lockup will become really easy. yes you have the momentum force, but its still being transferred thru your tires UNLESS you lock the brakes, then you just skid.
If you do go overkill on the brake calipers, it will increase your pad life and decrease wear, but it will mean easier lockup unless you run a master cyl that is exerting less pressure. Splitting a single master that was meant for a single caliper into two calipers may decrease the pressure to around where you want it. also a splitter will ensure equal brake pressure between the calipers so you dont go spinning out!
thats just my 0.02
