Hey new to the forums so sorry if i post this in the wrong section. I am having troubling with my modified predator 212 non hemi. I can not get it to run correctly.
My mod list is :
Gov removed
18lb springs
1.3 ratio rockers
7 degree timing key
0.10 head gasket
billet rod/flywheel
vm22 chikuni carb with 125 jet
trumpet exhaust
Now the problem I keep having is I can not get the engine to run without the choke and i have a loss of power. The engine dies immediately if I turn the choke off. Now I can sometimes get it to run with the choke off if I play with the throttle but as soon as I rev to full throttle it dies . I have tried adjusting the idle and air/fuel mixture screw that does not help, I have also checked valve lash maybe 5 times now, I have also uninstalled/reinstalled carb multiple times just to make sure the o ring is lined up with the intake evenly. I even sprayed carb cleaner around the intake to see if the idle changes and it does not. Do you guys maybe have any tips or suggestions to point me in the right direction
My mod list is :
Gov removed
18lb springs
1.3 ratio rockers
7 degree timing key
0.10 head gasket
billet rod/flywheel
trumpet exhaust
