Ok So ive put back in a stock timing key checked to make sure the o ring on carb and intake is aligned again even checked valve lash again and its set at .003 and my coil gap is set at .030. Ive even tried with gas cap on and off to see if its a venting problem even moved the c clip up on the needle and bike will still only run with choke on. Could the 1.3 rockers be a problem?
