OK, I finished the brake return spring bracket and could technically ride the bike now. The To-Do list is now:
1) Paint and mount the chain guard. I STLL NEED INFO ON HOW TO ARRANGE THE MOUNTS AND WHETHER I SHOULD BE DRILLING THE BRACKET OUT FOR THE LARGER ENGINE PTO BOLT
2) Mount the pegs. they need to be slightly massaged to work. nothing a little grinder time won't fix
3) Kick stand
4) RIDE!
Here's the brake spring bracket. This allows me to push the engine all the way back to keep the chain as far off the engine plate as possible
Also, do you think there will be an issue with the exhause pointing back towards the gas tank? The outlet is offset, so its not pointed RIGHT at the tank, but its close enough that I might make a deflector to push the exhaust out the side. Here's a pic:
Otherwise, here is what she looks like:
