Tubing rollers needed
Stab in the dark, I know, but I'm looking for a set of tubing rollers for 1 3/8" tubing to fit a Harbor Freight roller. Swag has them, but trying to avoid having to buy new for putting a slight bend in only two pieces.
Thanks
For a slight bend you don't need a correct fit. I roll 1'' conduit in the 2'' rollers all the time. I can roll a 24'' inch circle with no problems. It wont collapse unless you get crazy with it. Just use light pressure and increase it slowly as you roll it back and forth. Never had a problem.
Doug
Doug, thanks. The most severe radius I'm looking for (at one point), with this 1 3/8" tubing, is an 8" CLR bend. Think I'll take your advice and try the 1 1/2" rollers this thing comes with. Seems like if you can roll 1" in a 2" roller without much of a problem, I should be golden with my attempt.
Thanks again.
