tule trooper drive system
I bought a tule trooper this past weekend. it has the original deepco clutch on a junk motor it came with. but idk if I will be able to get it off without damaging it. so what I can replace it with. I still gonna use the pulley on the gearbox
mchadsey1
If the motor is beyond repair cut the crankshaft to make it easier to drill or press out the shaft to save the clutch.
mchadsey1
we used a hacksaw and sawzall and got it cut off. now we have it soaking it at and acetone for 24 hours and the we will try and get the shaft outta the clutch
Now that the clutch is off the engine can you get the springs out of it ? If so remove the springs and . Localize some heat around the clutch . Then let it cool and repeat a couple times this may break the bond between the clutch and the shaft.
to take it apart u pry up those 4 plates with the slot and rotate them 1/4 turn and it should come apart right
A heat gun and some candle wax...
Heat the whole assembly either on the grill, in an oven or with a heat gun, melt a crayon or candle into the space you want to separate and let it cool. Then knock the shaft out with a hammer and a brass drift.
Please don't laugh at me, this has saved my butt many times.
