Yes, if you have an adjustable HS body carb that would be about ideal.. The OLDER tecumseh two stroke carbs are fully adjustable.. Some are, some are not.. About like the vertical shaft motors.. For whatever dumbassed reason, they have been putting prejet primer carbs on push mowers for 40 years..
They've had one screw main fuel only adjustable two stroke carbs for 40 years also..
It seams to be (what it's on) has the biggest factor there.. Lawn mowers or snowflippers, something that just runs one speed all he time, doesn't need adjustment as much as something that throttles up and down....
Hs40 50.. H50 60.. Those are all about the rite size, Most of the Tec carbs, from like 3.5 to around 6 are just about the same CFM.. theres like a REALLY SMALL 3 horse carb, usually on the old old H25's or some of the old old sidewalk edger 3.5's..
but typically any of the newer or big iron flywheel 3.5 horse.. through like 5 to 6 horse power, are all right around the same size ventury... there's like 15 different sizes, and like 3 different sizes for the 3.5 - 6 range..
But HS40 is just about right.... AA battery sized hole... Maybe upwards of a dime... Not much over a dime though or it will be too big, and you will just have a hard time pulling fuel at idle, and acceleration will suffer... You need some pretty major upgrades if you are gonna match an 8 horse carb to 139CC motor..
