Using JB Weld to stiffen upside cover And block around the bearings
Building a predator 212 Billet flywheel and rod along with a Cam 22mm carb. Looking to get about 12 to 14 horse out of it is it worth stiffening up the bearing areas with JB Weld Like to know your guys thoughts...
It helps stiffen the side cover and keep less oil in the crankcase. Guys do it for the dyno SA challenge where they cant run billet side covers. Running less oil in a minibike is probably not a great idea.
