Vintage Snowblower
Mr. Pink
As I was contemplating purchasing this, someone else snatched it up.
My question for when the next time one of these becomes available, does this Briggs and Stratton/snowblower setup always have a 3/4” keyed crankshaft PTO?
And if it does, is the PTO end threaded for a retaining bolt?
I’m also assuming that it is not a big deal to swap the cam and side cover to eliminate the reverse shaft, correct?
It was a bit scary, but I was able to successfully drill and tap the crank of my current engine.
Biffmini
Most are 3/4" keyed, drilled & taped
I'm sure there are some oddballs out there.....
Yes too eliminate reverse, cam & cover swap. or cut shaft off & run it
Mr. Pink
So is it also safe to assume that "most" rototillers with a Briggs and Stratton from this era are also 3/4" keyed, drilled & taped?
I had a big disappointment when I removed the water pump from this 1980 Briggs and found that the crank was 5/8" and threaded.
Oh well, lots of other usable parts on this engine. And I only paid $20.
Triley41395
Just about every tiller I have seen you can see what size the pulleys are and if the end of the crank is tapped. I bought 30(I know too many) engines this last spring and summer,both tecumseh and briggs, and all but 2 were 3/4 inch and threaded.
That is useable. Just need to cut a keyway easy
I just use a thin cutoff wheel small diameter and cut the two edges and clear out the middle. finish off close to the engine with a smaller dremel wheel. It doesnt have to be perfect. But my results always turn out pretty close.
Mr. Pink
Even though timing is not an issue, is the PTO keyway typically at a specific crank angle in relation to TDC?
