You ''still'' need to check your valve clearances @ ''true'' TDC ,, with '' both'' valves ''completely'' closed,,, like I & the others stated before.
Spec. gaps are definitely .004 - .008,, & ''please'' use actual feeler ''gauges''.
I used to set them @ the middle of those specs @ .006, as I stated before also.
A crude way is,, you can stick the eraser end of a pencil in the plug hole,, ''with the piston up'',, & mark the side of the pencil with a marker next to the top base of the plug hole,, ''for reference'',, with keeping the pencil in the hole to watch in making sure the piston is all the way up,, while slightly &''slowly'' rotating the crank back & forth a ''wee'' bit,, & also at the same time watching for ''any'' valve train movement.
Around there is where you want to check your gaps .
Let us know what the gaps are.
I
