I have an hs40 that I picked up but the crank was drilled and tapped off center, its a good running motor and its getting hard to locate these 4hp in my area, at this time I don't have the knowledge to replace the crank but was wondering if I can fill the 3/4" deep hole with the welder and drill and tap it? is this possible or is this not that big of an issue being off center or will it cause vibration causing damage to the side cover bushing if I use it like that?
