Twenty bucks, I couldn't say no. There's a plate between the handle bars that was sprayed over with green paint, and then some kind of mounting plate (headlight, perhaps?) was screwed over it. Across the bottom, I can clearly warns you about 'off-highway use only', that sort of thing. Across the top, looks like a ENG, EMG, IMG - then everything else is obscured by rust from the mounting plate. The next line down, a big capital P - then the same deal with the rust. The engine is a real (not clone) Honda GX240 Max (obviously, not original) - needs a recoil starter and a carb kit, but has good compression and spark, I'll play with it some more when I get a chance. Looks like modifications were made to the driveline, but seems like it started out as the trike that it looks like today. Any ideas?
