What Mini Bike Is This Please, Help Identify!
#41
I don't know, really. But as Mr. Trotter's narrative explains, it was the first of three runs, and the early product of an inter-family competition involving the legendary tote-goat. Moreover the first picture @Richard Trotter posted looks like the same red as yours. I'm thinking that could be a real hit at the next tote-goat meet-up. Especially if you only gently cleaned it up and got it running. But by all means, recover the seat to look more original. But what do I know? These little ponies could be a dime a dozen?
My passion is restoring items to original condition, creating historical accuracy of the original creator. I feel satisfaction in the journey of creation itself.
#42
An update to the project. I got the Magneto style coil to eleminate a points and condenser ignition system. However, theres a slight issue with the directional air deflector. When installing the original coil. The original setup, there is an upper stud that retains a certain position for the deflector and the lower bolt passes through the coil hold everything in place. So, I made up in copper, the metal that I had as salvage, bent up a bracket with a rivet and bolt to the block, something to retain a position that wont move. Being copper and folded over three times to create a thickness of .1270. Its just an idea and scrape metal to retain a non moving deflector. I also found a debris screen, painted up alittle to kind of retain original look, alittle to dark but it matches the fuel tank straps. LOL!
#44
I truly thank you for the response and the information, and good to know for everyone here. I have example 2 flywheel, and I must be lucky, there's a lot of spark. I mean, jolt your rear end spark! However, the coil that I purchased. There is a marked directional position marked where it must face, "Towards the Cylinder Side." It's a very nice upgrade! The engine I have is what was in it, maybe an upgrade during that period? As shown in your example, I have the flywheel in example two, but the four-post coil to block setup as in example one.
mchadsey1
There may be a problem. The number you posted from the fan housing doesn't match the coil type. These different coils have different flywheel magnet polarities. A new style coil won't work with a old style flywheel.
I believe at 1 time you could send your flywheel back to briggs and they would remagnatize with the correct polarity. I ve also heard of others mounting the coil backwards . (Facing cylinder side of coil toward the shroud )
#47
In research, when converting over to a Magneto style. Reversing the coil to change polarity would correct a no-spark situation as you have described. However, when I spun the engine with a cordless drill to see if I had a spark. Oh boy, did I ever! A real snapper! It would definitely be an awakening moment if, per se, you accidentally touched the end of the spark plug wire lead. LOL! A nice electric snapping sound when grounding out to the cylinder head! I've reconditioned a few Briggs in the past. However, I don't think it's possible that such a nasty electric arc could occur without a media cleaning. I media cleaned the flywheel, and with a brand new original Briggs and Stratton factory direct coil could be the reason. I was like, DAYUM! LOL!
#51
I have been watching this thread with interest. I am curious as to how you will be connecting a throttle cable to that carb.
Michael
Great question; however, I have a plan to make up something that will work really nicely. I'm not close to working on that right now, but I will post when I do.
#54
Depends what you want out of it. Depends on the tote-gote market. I just have heard certain unique items like your may be more valuable left as-is.
For me, the passion lies in historical restoration. Call it, historical preservation. I find joy in as close as possible, recreating a piece of the past that is now long gone. While this work might seem trivial to some, it holds immense personal value for me, representing a family's history that started with building motorized vehicles for mountainous adventures.
Minimichael
Looking good. Love the older shroud design. Your coil bracket looks period correct too – though I'd check it after very rough rides, since what copper lacks for tenacity is readily made up for in pliability. You could find your fastener loosened.
#58
I've considered the potential for a rivet to loosen under vibration and stress, and as previously discussed, I've decided to upgrade my copper bracket connection for improved reliability. I plan to replace the rivet with a nut, bolt, and washers, which I believe will significantly reduce the risk of a minor catastrophe.
I really appreciate you and the period-correct comment. I had a sheet of copper saved that came off a copper-roofed home that was demolished. Could you imagine the cost of a copper roof home today? The art that the home had was amazing, but was ravaged to the point of a total loss in Detroit! I'm sure you all know about Detroit and the issues. That's another story! LOL! I may just rethink and find a piece of sheet steel similar to the thickness of the deflector, and bend it the same. Again, thank you and all the help. It's very appreciated
