Wheel bearings
Does anyone know how to remove bearings from rear hub of a Manco thunderbird?also their seems to be something in between a spacer or so. I guess axle slides thru it and prevents it's from collapsing itself when tightening it.
Thanks.
buckeye
Yep, there is a spacer in them.
What I do is get a long bolt.
Slide it in one side of the bearings.
Slide it down until you find a lip.
You will feel it.
Then keep that bolt, punch, whatever, you use and tap, tap tap on that edge.
The bearing should start to come out, hopefully.:laugh:
