Any vertical shaft experts on here? I'm building a pressure washer.
I have two, good running, Briggs & Stratton Quantum vertical shaft pressure washer engines and I'd like to use the better of the two but I'm not sure which that is.
Engine 1: Model 12H802-2349-E1
1998 model year
6.0 HORSEPOWER, no TORQUE number
Engine 2: Model 126T02-1044-E1
2007 model year
6.75 TORQUE, no HORSEPOWER number
190 cc
I realize they are both the same cubic inch displacement (12) and same basic family of engine (L-head Quantum) but one is rated in HP and the other in TQ so I'm not sure if one has a higher output spec than the other or if they are 100% identical.
They both have the same carburetor setup (non-adjustable "emissions" carb, with choke, and w/o primer), same shaft diameter and length, etc. I assume neither have cast iron cylinder bores because that's usually advertised on the stickers.
Any ideas? Or are they actually identical?
1998 model year
2007 model year
190 cc
