So I was buying/restocking some bodywork type stuff a while back on Amazon and these mixing boards popped up. I had never seen them before and just always used either the plastic ones that never get clean or chunk of cardboard or something out of the garbage can to mix filler or jb weld on.
I am loving this, you just peel off the sheet and toss it after each use and have a clean surface to mix on every time. It’s glued on three sides so it stays in place, until you peel the sheet off. But basically a notepad on a hard backed board.
this one is the small version which is great for the engines as I usually only need to mix up small amounts for spot jobs. They have a full size one as well they come with a decent little applicator as well, I’m just using the popsicle stick for a quick and dirty jb weld fill job making a non slanted dual oil outlet side cover a single oil fill slanted application version.
