I bought a new reproduction Rupp switch from Blackwidowmotorsports and I have a 30 watt low beam 45 watt high beam Daymaker LED clone that I bought from Amazon. According to a calculation the max amp that a 45 watt bulb would draw at 12 volts is 3.75 amps. Will the Rupp Roadster 2 factory style switch be able to handle that current of 3.75 amps? I am using 18 guage wire which can safely handle more than 10 amps of current so the wire should be fine with this headlight.
